i want to ask you guys why my khyber's handbrake lever gets extremely hot only after a 10 min drive ... rear brakes are working fine no traces of over heating ... what can be the issue ... needs expert guidance
Hand brake getting hot is not a sign of the rear brakes being overworked.
It's getting hot because it's a metallic bar with most of the insulation not installed from the factory. Nothing's wrong.
it gets hot due to exhaust pipe underneath. check its insulation, I believe there's supposed to be metal plate between car body and exhaust pipe
Thnx bro
Same is the case with my Khyber
I think it is because of Engine heat as no firewall is installed there
Any known solution regarding the matter
@xzap042Which sort of metal between body & exhaust?
@xalmanreyazAt least, i have not found any solution regarding this matter
