I have mehran 2007 ,almost 3 months back my car's axel (gauda) started to give tuk tuk sound so i replaced it with chinies one , 3 months later i noticed that the boot tore off so i went to the mechanic and kharadiya to replace the boot but when the mechanic tried to pull out the cupa (as they call it in punjabi) of axle it wasnt coming out (according to the mechanic this is the problem with chinese one ,they get stucK) he tried and also had few strikes on it but it didnt work so he attached new boot without removing kupa ....but after that when i drove the car that side (that is left side) started to vibrate and as i was increasing speed the vibration was also increasing and when that side hit any khada ( broken part of road) it gave very serious jerks and vibration .....
i went back to him he said may be because the chinese gauda is done so i asked him that i have the original gauda of my car which hasnt been repared previously so what if we can repare it and use it so to check whats the problem ....
after contiously hitting, striking and pushing finally the chinese kupa was out ....he said you should be thankful otherwise we wud have to open the gear box ....
so the kharadiya repared the origina gauda and mechanic fitted it in but the problem is exactly the same again vibrations and svere jerks as it hits some khada ...the vibration only happen on that side ,,,,i am seriously worried .....what is the possible cause...i have done all i cud but no soultion
plz reply me what can be the possible problem ...has it something to do with the strikes ????? or wat
Click here for SOLUTION
