For Sale D15b Dual VTEC Engine
P2j original Manual ECU OBD-II (rare)
With B000 gear box which is shorter in Ratios hence better for drag.
Also have Aftermarket Headers for the same engine at additional Cost
Lightened Flywheel Also Available at additional Cost
Engine has not been used Locally.
D15B VTEC
[LIST]
[*]Displacement : 1,493 cc (91.1 cu in)
[*]Bore and Stroke :75,0×84,5 mm
[*]Rod Length : 137 mm
[*]Rod/Stroke : 1.62
[*]Compression : 9.3:1
[*]Power : 130 hp (95.4 kW, 130 PS) at 7,000 rpm
[*]Torque: 106 Nm
[*]V-tec switch over : 5,500 rpm
[*]Redline : 7,200 rpm
[*]Rev-limiter : 7,500 rpm
[*]Valvetrain : SOHC (4 valves per cylinder)
[*]Fuel Control : OBD-2
[*]ECU : p2j (small case ECU)
[/LIST]
For further details kindly call or text 0321 3070100
