One Of The Most Advanced Components For True Mobile High Fidelity.
The amplifier can deliver a full 75 W + 75 W of output power, while keeping distortion to the negligible level of 0.003 percent. These are under rated amplifiers and their actual power ratting is 90 watts per channel.
Specifications:
MADE IN JAPAN
Continuous Power Output: 90 watts per channel into 4 ohms
Power Bandwidth: 5 to 50000 Hz.
Total Harmonic Distortion: Better Then 115 dB.
Frequency Response: 50 to 50000 Hz.
Signal To Noise Ratio: Better Than 115 dB.
Damping Factor: Greater Than 1000.
Input Sensitivity: 0.2 to 0.8 V
Stereo Separation: 85 dB.
Power Source: 14.4 V DC negative ground.
Power Consumption Maximum: 27 A.
Load Impedance: Above 4 ohms.
Dimensions: 320 x 52 x 160 mm.
Weight: 3 kg.
Condition: Excellent, No Damages Or Repairs
PRICE = 3900
For Further Details Contact ANAS CHAUDHRY 03338445526
