Up for sale is some of this SQ stuff.
Details are as under
DEH-P80RS
Features
White dot-matrix OEL (Organic EL) display
Aluminum-plated face panel
iTunes AAC playback
WAV file playback
iPod adapter ready
Burr Brown advanced segmenttype D/A Converter
Built-in DSP
EEQ
5-mode preset equalizer
2-mode custom preset equalizer
Auto EQ
Auto EQ for 3-way network
BBE digital sound processing
Digital listening position selector
Auto time alignment
BMX (Bitmetric Equalizer)
L/R independent 16-band digital graphic equalizer
L/R independent 2-way crossover: HPF/LPF
L/R independent 3-way crossover: high/mid/low
ASL (Auto Sound Levelizer)
Auto-slide face
Rotary Commander
3 gold-plated RCA preouts (front + rear + subwoofer)
Level indicator
Spectrum analyzer
Multi-language display (English/Spanish/Portuguese)
CD-IB100II - iPod? Interface Adapter for IP-Bus Equipped Receivers | Pioneer Electronics USA
Soundstream Reference 800.4 Amplifier, 4 channel SQ amplifier
SPECIFICATIONS:
4 x 125 Watts RMS @ 4 Ohms
4 x 200 Watts RMS @ 2 Ohm
2 x 400 watt RMS @ 4 Ohm
high pass filter 30 - 4000 Hz
Subsonic filter 10 - 100 Hz
Hawkins Bass Control 0 - 18 dB
Hawkins Bass EQ 18-80 Hz
input sensitivity from 0.15 to 12.0 V
Bi-linear crossover selector
mega-FET power supplies
Gold-plated RCA connectors Balanced line inputs
2 Maxi Gauge Power Terminals
Special coated heat sinks with optimized heat dissipation RUBI ? - pulse-controlled power supply
STACT ? - Reduces harmful voltage spikes by 50% Trident ? - 3-overload circuit
Harmonic Bass Alignment ? - Precision Bass-circuit
IDI ? - Protection status display
BIP ? (Bias Input Protection) & ndash ; bias protection circuit
Ultra-Low ESR Capacitance Bank - Hi-Speed Power Supply Technology
4 x 125 / 200 watts RMS at 4 / 2 Ohm HP LP filter 30-4000 Hz,
Hawkins Bass - Control 0-18 dB,
Hawkins Bass EQ 18-80 Hz,
Subsonic Filter 10-100 Hz,
0.15 to 12 V input level
Triple Darlington output circuitry
THD <0.02%
SnR 115db
Damping Factor >500
DEMAND :
P80RS+IB100 = 24K (bit negotiable) (S O L D)
SoundStream = 18K (bit negotiable) (S O L D)
For Contact or offers : 0333 425 6800 (Usman)
