Guys i need a little help here... i need to know how to set auto door lock in Toyota Axio X 2007. i have tried as the corolla 2007 user manual says. but it didn't work for me.
it says,
The mode toggles through from mode
1 to mode 4. To change the mode, do
the following:
Set the interior light switch to the
“DOOR” position. (See “Interior light”
on page 93 in Section 1−5.)
Shift the selector lever into the “P”
position and close all doors.
Turn the ignition switch to the “ON”
position.
Within 5 seconds after the ignition
switch is turned to the “ON” position,
push and hold the power door lock
switch on the front side for about 5
seconds.
The interior light will flash to indicate
that the mode has been changed.
The flashing of the interior light indicates
the mode which has been selected.
Flashing once, the function has
changed to mode 1.
Flashing twice, the function has
changed to mode 2.
Flashing three times, the function has
changed to mode 3.
Flashing four times, the function has
changed to mode 4.
If the battery is disconnected or run down,
the mode may change. Set the desired
mode by following the above procedure.
