You need a liana 1.6 sports JDM engine, you need to change your brake system and do some adjustments. I am not sure whether you can install a turbo on a suzuki engine. But without turbo, it will cost you 1.5 lacs. The khyber you want to buy should be of good condition. I wont suggest you to do this because at higher speed khyber will not be controllable. If you are a beginner. Get yourself a dolphin civic, 1993 to 1995 and swap it with 1.6 doch engine or h22 or k24. Keep it stock. See how it performs, then step up slowly as your pockets allow you and the way you want it to be.
