Hi guys,
I want to ask about the gear transmissiin problem of faw v2. Sometime when I start engine and try to shift into first gear forward or back gear i am unable to shift it. Problem persists then i switched off engine and shift gear and then start engine while in first gear. after running/moving some distance it starts working normally...First I thought it could be a clutch wire problem but if it is so then it should not work after running some distance. even it should not work while engine is off....Can someone guide me what is the real problem?
