if it stopped working suddenly, first check the fuse box.
is your car new, or has been in the hands of the monkey team of mechanics and electricians?
there seems to be an ac coil in the back, which has a drain, which appears to be choked or not draining properly. would suggest you find the drain from under the car and then trace it backwards. clean it
