Ok I tried to understand this and used my hardly used brain heh.
Because we dont have card or amplifier available we will use IGF signal to ECU ACT.
how what we need to do is like this.
Steps how I am gona do it.
1 - I will take the cable out of thermostate which goes to Compressor and connect it to AC 1 as well so it will see positive when a/c is on.
2 - I will Install a Relay that will get positive from Thermostate to Compressor wire and connect IGF to ACT so when thermostate switches AC on the ACT will see IGF.
3 - I will give positive to vacuum solenoid (From battery with fuse) and connect its negative to ISC PIN
I hope i am correct
Ahsan if above is correct we can do it togather some time
Lets wait for Zulfiqar bhai..
My ECU Pins. What VSV do btw? and AC 2 Pin?
