i think my AC is not working so well.
after the swap i got the 3 wire compressor.
i had the evaporator cleaned using acid, they replaced the txv because it was supposedly blocked.
when they tried to charge it, they couldnt switch on the compressor coz of wiring so they hot wired the compressor clutch and charged it with refrigerant.
later on i sorted out the wiring, had to short out the sensor on the compressor coz it wasnt working. now the ac amplifier is in full control of the compressor clutch and switches it on at its whim, just like before.
cooling is not that great however. even on a cool 28-30degree celcius rainy evening and having the fan at the slowest speed, the AC wont trip, it wont throw out ice cold air, it'll trip after maybe 7-10mins running consistently on idle after a 20minute drive with AC switched ON (engine idling with AC at around 900rpm).
they charged the refrigerant with the compressor hot-wired. could that be a problem? can pressure switches have hindered the proper filling of refrigerant gas while compressor was hot-wired?
