I have driven about 30000 km on this vehicle mostly on highway, desert and mountain roads and following are my observations
Power: If your last vehicle was not the one with 1KD-FTV then this one will give you decent performance feel (catches rubber in first three gears
although its light weight rear helps it to do so but still for a diesel vehicle its sweet). felt it lacking low end torque while going up towards saif ul malook on low RPM but it was easily solved by puting it into low transfercase gear with higher RPM. In desert it was awesome. Does lil over 150 kmph as max speed.
Breaking: This is the best part: I tried it on an empty highway by breaking at 150 kmph with full force and it stopped in a straight line without skidding at all hence its ABS and balance is good.
Suspension: Now we can never compare it with a car as its bumpy if driven without passengers but better than many older SUVs. But when you are cruising on bad bumpy highways on high speed it glides smoother amazingly.
Overall: If you are replacing it with your car for mostly city usage its a Big NO, and if your usage includes touring to distant places like northern areas etc then its strongly recommended. A brand new 4x4 in this price is nice. (and with this resale
value too)
