Dear Brothers,
Up for sale is one of my Brand New/Unused Flex XC3401-VRG Forced Dual Action polishers! :)
Flex is among the most highly praised and talked about polishers, used by the Pros throughout the world. This particular DA has forced rotation which means it won't slow down or stop rotating even if you apply pressure on it or use on a curved/angled surface!
Ordinary DAs stop rotating and just keep vibrating when they are put against an angled surface, a bent or a curved body line... this is because they are clutch operated. However Flex 3401 VRG is a one of its kind forced rotation dual action polisher! Coupled with its 900 Watts motor, this DA is designed to remove some serious paint defects!
Unlike ordinary DAs that don't really work much on our local paint jobs, this Forced DA does remove all kinds of swirls and scratches! To be honest with right combo of product and cutting pads, this DA beats my rotaries with its superior cutting and finishing results!
Its a 230 Volts edition which means no need for any converter, as in case with most of the imported polishers... for me attaching & fidgeting with a 220-110 volt converter is a nuisance!
I imported 2 of these a month or two ago and have been using the other unit. By far its the best and my personal favorite machine in the shop! I specifically choose this model to work on high end cars with irreplaceable paint jobs, rotaries can sometimes damage the paint work if not given close attention to while working. However this machine is 100% safe! You can't really burn paint with it (unless you purposefully try to) and its cutting and finishing is STRONG! Leaves no holograms or compounding swirls as in case with rotaries, leaves an awesome finish!
Please note only 1 Brand new unit is for sale, I am keeping the other one as its a must have and a personal favorite of mine!
Technical Specs & Features:
- Forced Rotation/Clutch-less Operation for powerful cutting action
- Strong 900 Watts Motor
- 6 Variable Speed Settings for cutting/polishing/finishing
- 8 MM Orbit Stroke - safe & easy use
- 3200-9600 Oscillation Per Minute
- 2.6 Kilos in Weight
- Trigger operated for easy operation
- Trigger lock option - helpful during long continuous use
- 9 ft. Tangle Free Cord - means no fidgeting with cords
- 230 Volts compatible to our electric regulations
- Comes with a standard 5.5 inch backing plate that's suitable with 6 inch and above pads
- I also have F.S. a 4.375 inch Flex exclusive backing plate that allows you to attach 5.5 inch ordinary DA pads and really opens up a lot more options for you to try new pads and combos!
I absolutely LOVE this machine and can go on and on about it!
It really is a best, safe and working solution for all kinds of paint jobs! It really has cutting power of a rotary and finishing of a DA. I have used this DA to remove imperfections left by my rotary! This is how good it is!
Enough talking now lets pictures do the talking:
THE BOX:
THE POLISHER, COMPLETE WITH ALL MANUALS & ACCESSORIES:
AVAILABLE 4.375 INCH FLEX BACKING PLATE FOR 5-5.5 Inch Pads
MY PERSONAL UNIT: (Works wonders with microfiber cutting pads)
FLEX XC3401 VRG Price,Review & Technical Specs on Auto Geek:
http://www.autogeek.net/flex-230-volt-polisher.html
Flex 4.375 inch Backing Plate (a must have) Price/Reviews on Auto Geek:
http://www.autogeek.net/flex-xc3401-mini-backing-plate.html
Price on auto geek is 470$ for 230 Volts version and 4.375 Inch backing plate costs 37$! Total: 507$
Each polisher unit has costed me 60ks here in Pakistan after paying for shipping, all duties, taxes and clearing charges and I shall be letting the polisher along with additional backing plate (4.375 Inch) go in ......
HAPPY DETAILING!
Cheers!
Contact:
Umar: 0312-475 86**
SOLD to a fellow PWer! Thanks!
