@4nonymous
Hi.
first of all mubarakbad for good purchase
Marla & Kanal terms r used in Punjab,AJK & KPK provinces while Square yards(Gaz or Gaj) is used in Sindh & Balochistan for houses while square feet is used for flats / apartments in Sindh & Balochistan
10 Marla means
10 Marla = 0.5 Kanal = 2250 square feet = 250 square yards(Gaz or Gaj)
It is quite good space & you can build economical house.
Roughly average cost of construction of house is calculated as
Rs. 1500/= per Square feet so
approximately,construction cost should be around 33,75,000, for safe side take approximate of 40 Lacs for High quality finishes:
It also varies how much your width & depth is, mostly in Punjab, you have 40 X 62.5 for 2500 sq. feet
40 is width X 62.5 depth or 62.5 (width) X 40 (depth)
(width is that part where your door opening will come)
so below one is good choice with open passage for light & air:
option 2:
if u want with broad drawing room/ sitting room:
option 3:
bahria most popular design for 200 -240 sq. yards
option 4:
3 diff. designs:
option 5: low budget but high living
if u have low budget but need hi living then make house on 5 marla & leave rest of 5 marla for open grass/lawn area,
it will save much of your pocket:
5 marla is almost near to 120 sq. yard (gaz) & economical maintenance
if u need construction guidance more or in lesser cost, u can contact me anytime dear bro
