So lets see if my bro is able to sell this car
he wants 88 hehe otherwise i will do the following work soon i am going for a power steering and whole front wheel hub with dics replacement i can also get the disc tooled and they will work but i wanna change them completely.
After that my plan is to re do all the wiring i will take out all the wirings of the car and we will re do them.
After that all the locks and door window machines will be serviced.
All 4 wheel bearings will be replaced.
A/C which was repaired and in very good but the ac mechanic told me to install Multi Aisle condensor in the ac to increase the cooling and take off load from the compressor and engine. 5000 Rs. All the new cars have multi aisle ones thats why the ac works so good in the old cars we have single aisle and that puts extra load on compressor and engine and also effects the cooling. Now in the past they were not available in the market but now they are coming in new.
The seat covers of the car will be replaced with factory fitted ones.
The meter of the car will be replaced.
The whole wiper set motor and all is old we will replace it.
The radiator of the car its a 3 channel one and working fine u will be amazed that i check my cars water level once a month and still i dont have to put 1 drop of water in the car its alway full MashaAllah. But i want to replace it with a new one or a good condition qabli.
One of the major things in these old cars are axle or goda in this car we are using conventional axle now we have this option in charade of cross type ones the advantage is they never give out noise and no vibration in drive so they will be installed.
I am looking for rear brake shoes of charade original ones not the local or chinies in red box just cant find that anywhere in the market :S
One of the rear door is rusted from inside and need replacement that is around 7000 Rs so that will be done as well.
One of the major things in car brake is the booster my mechanic told me he saw a biger booster for charade so he will try to install that in the car if that worked brake will be amazing its already very good bcoz we installed new booster but looking for improvement
after all above is done ill go for paint
