Salam pakwheelers. need your suggestions with some issues with my commando as its my 1st time owning a jeep ever.
1- Recently baught a Mutt m825.. rear differential makes noise on 4th gear and higher speeds. its too loud and you can't hear the person sitting next to you. someone suggested installing prado SSR differential and problem would be fixed for long time.
2- it has 1800cc petrol engine, and gear shifting is difficult some time. you have to try and shift in 3rd or forth gear on idle and then you can shift into 1st or 2nd. any ideas what's wrong and how can I get it fixed?
3- The original braking system is very dated and unreliable. jaming the wheels or don't work with soft paddle. no way I can drive in the city roads with that. can I install disk brakes instead?
Also, can someone please suggest a well known mechanic in pindi/isbd area who knows the jeeps well?
thanks in advance
