FOR SALE : One of the best american car detailing brand "Ultima"'s product
ULTIMA TIRE & TRIM GUARD PLUS (new formula)- 12 OZ.
Status : Reserved (Half splits for the bottle are RESERVED)
Incase anyone needs some, I can give 3oz (90ml) from my personal bottle in a very nice new clean dispensable bottle. The 3oz should be enough to restore and protect your exterior trims for a very long time. Price for 3oz would be 950. [STATUS of this 3oz: Reserved for @omarabdullah022
Ultima Tire & Trim Guard (UTTG) Plus is a new polymer coating that can be applied to most flexible surfaces (vinyl and rubber) and hard surfaces (plastic and metal) to coat, seal, protect and beautify. No ordinary ?dressing? lasts as long or protects as well against pollution, ultra violet light (sun), road salts, harmful ozone, creosote and more. While its an all rounded for exterior surfaces, its main area of expertise is the Exterior plastic (and you'll in the pictures below how it restores/protects your exterior trim from fading, something that is very common in our cars). We wax our cars frequently but the exterior plastic gets neglected and starts to fade. The interior dressings when used on exterior plastic last very little. Use this to restore your faded plastic and keep it looking black/darker and protected. When used on the side walls of the tire (after its been thoroughly cleaned), your tires will continue to appear dark and will repel water. Even on tires it lasts for months.
The long lasting Ultima Tire & Trim Guard Plus formula protects for months, not days or weeks. This space age coating will not wash off. On glossy trim it maintains the shine and prevents corrosion. On black trim it maintains a dark, satin appearance. You?ll see the protection with each wash by the way your tires and trim bead water.
Ultima Tire & Trim Guard Plus is a hyper-concentrated formula. A single 12 ounce bottle is enough product to properly treat your tires and trim for a very long time. A small amount of Ultima Tire & Trim Guard Plus goes a long way to coat, seal, protect and beautify tires, wheels (painted, chrome, polished), bumper trim, plastic grills, fascia, valances, rocker panels and the engine compartment. Our super durable formula protects for months, but you may apply it as frequently as you like.
KEY BENEFITS:
- Boosted by Polycharger? for superior protection
The first and only multi-surface tire, trim, and wheel sealantLasts for months, not days or weeksProtects against pollution, ultra violet light, road salts, harmful ozone, creosote, and moreWheels rinse easily without any harsh cleaners needed
INSTRUCTIONS:
Make sure area to be treated is clean and dry.On large areas, spray directly on the finish and rub in with a foam applicator.On smaller surfaces, spray on applicator and apply to the desired finish.On porous surfaces, such as tires and rubber trim, allow Tire & Trim Guard Plus to dry without buffing.On hard, glossy surfaces, such as your wheels and chrome trim, buff dry to a high gloss shine.For additional gloss on tires, a second coat may be applied after 20 minutes.
RECOMMENDED SURFACES:
- Tires || Wheels || Exterior rubber trim || Exterior plastic trim || Exterior vinyl trim
Note: For exterior use only.
PLEASE NOTE THAT THIS PRODUCT ISN'T ONLY FOR FADED TRIMS. IF YOU HAVE A NEW CAR WITH GOOD LOOKING TRIM, YOU STILL NEED TO PROTECT IT WITH UTTG BEFORE IT STARTS TO FADE.
Some reviews from the internet:
If you search on youtube for the product name, you will see a video by Garry Dean restoring the exterior trim as follows:
Another 50-50 shot showing the rear surface wearing UTTG:
A closer look between an unprotected surface and UTTG protected surface:
UTTG on tires. The right side wearing UTTG and notice the middle line thats unprotected (without any dressing)
Some more before and afters
And great water beading that will bead water away and keep the plastic easier to clean
PRICE : Its sold in the US for $32. The conversion when paid from a credit card is about 107-108, making the total to about 3400. I AM SELLING IT FOR A ROUNDED Rs.3000
Local pickup in RWP/ISB. Courier option to other cities (Rs. 150-180)
While it may appear expensive. But take a closer look, you'll find that they are actually less expensive than most traditional products per application. It takes less than a 1/4 oz of Ultima and an ounce of a competing product for certain jobs. The competing product would have to be 4x cheaper per ounce in order to compete with the cost. This is before you even factor in the durability of Ultima products which last much longer. Ultima products certainly last much longer than any product that is less expensive per oz.
Note: Incase some of you want to split the product, I would be happy to do that. So put down your name for the split.
Half and Half split
Original Bottle (with 6oz UTTG) -- 1700 Reserved by @vague_one
Rebottled in a really good quality bottle that I can show you first before pouring (with 6oz UTTG) -- 1550 Reserved for @Vajih102
