Slam. i have cultus vxr. whenever i release clutch quickly i feel that only front left wheel skids while the right one moves like the back wheels. if its a problem then what needs to be checked/repaired??
Click here to go to the ANSWER
Its front wheel drive, its supposed to act this way
Sent from my Nexus 7 using PW Forums mobile app
its normal, there is a differential(not sure what is it called exactly) in the cars which transfers more power to the wheel which has lesser resistance.
thanx @sahhil_22 and @hellsguardian
The left wheel starts spinning because your car is right hand drive. The steering assembly is to the right... Also the driver sits on the right which gives more grip to the right wheel... this is most likely the reason why your left wheel spins...
