Items for sale were purchased for a project but now taking a different direction
1) Brand new imported from Japan 1JZ-GTE VVTi CT15B (single Turbo) steel turbine wheel with reinforced shaft
replaces the weak ceramic blades with a much more stronger and peak flow design turbine wheel and shaft made from Inconel alloy (stronger than steel) balanced and tested
-For reliably boosting your CT15B above 1 BAR(14psi) of boost easily without breaking
-For running Bee*R and antilag systems without any issues
-For sustained high boost driving as Inconel blades withstand extreme heat and pressures
-Improved blade design with lightweight alloys that allow for instant response and peak power figures
Will require professional fitting or if you know what you are doing with turbos
HKS SSQV 3 Blow Off Valve (Genuine unit in mint condition *used)
*Genuine Japanese unit and this thing holds high boost and has an iconic sound
Brash Boy Japan JZX100 Engine Torque Damper (used unit has some marks and plates have surface rust but the unit itself is a 100% functional) (universal use by changing the mounting plate to suit any RWD car)
Engine torque damper from Brash Boy Japan used for transferring power to the wheels more efficiently by eliminating engine vibrations and movement from breaking mounts and cross members/chassis rails
-Crisper shifts and downshifts
- Power Launches put more power down to the wheels instead of wasting it shaking the engine
- Engine Mounts/ transmission mounts/ differential mounts and suspension bushes have a prolonged life
Items are available in Peshawar and can be shipped to anywhere in Pakistan
Pricing and contact: 03419428529
