Hay everyone, I'm selling my custom amp rack that was designed to fit in the boot of a Toyota Corolla. The amp rack is made entirely out of 1" mdf with support brace and magnetic catch latches. The lid can be opened up if any kind of tuning is required on the amps. I had 2 amps, 2 massive crossovers and 2 distribution blocks all packed in there and there was still room left.
The amp rack also comes pre installed with zip tie clamps for a neat and clean install which can be removed and installed anywhere else on the amp rack
The amp rack is covered in the same carpet material that's found in the trunk of these cars. It's super durable so you can put as many things on it without running the risk of it collapsing. It hardly extends to 1/3rd of the trunk and is 4" high so doesn't eat into the trunk space and it keeps your ice gear safe
Below are the images of the rack when I was still in the process of running wires
c
Here's the amp rack placed inside the trunk. It blends in, doesn't stand out, keeps everything hidden and still leaves you with ample trunk space. Best bit is, the sides are open for air to pass by but you can easily install a inlet/outlet dc fans too if need be
