For sale are these beautiful 3-way component set from GroundZero. Hand made in Germany, the Plutonium series are GZ's top of the line range of SQ car audio equipment. This particular component set includes the 4 massive Passive crossovers which are Bi-amp capable. The Original
wooden box has been kept with care too
The description for the components are as follows
6.5” Woofer with alu-ceramic cone and linearised ferrit motor (GZPK 16SQ) - 3.15” Midrange with magnesium cone and compact neodym motor (GZPM 80SQX) - Resonance free cast basket - Rubber surrounds and connex spiders - 1.1” tweeter with coupled chamber and 2-layer coated silk dome (GZPT 28SX) - Speakers verified with the Ground Zero owned Klippel system
3 Way component set
Diameter of midwoofer or midrange165 mm / 6.5″ (Woofer) - 80 mm / 3.15″ (Mid)
Mounting diameter of midwoofer or midrange 143,5 mm / 5.65″ (Woofer) - 94 mm / 3.7″ (Mid)
Mounting depth of midwoofer or midrange 68 mm / 2.68” (Woofer) - 34 mm / 1.34″ (Mid)
Voice coil of midwoofer or midrange 36 mm / 1.42″ (Woofer) - 25 mm / 1″ (Mid)
Cone of midwoofer or midrange Alu-ceramic (Woofer) - Magnesium (Mid)
Dustcap / Phaseplug of midwoofer or midrange Alu-ceramic (Woofer) - IMPP (Mid)
Basket of midwoofer or midrange Aluminum cast
Magnet of midwoofer or midrange Ferrit (Woofer) - Neodym (Mid)
Diameter of tweeter 54 mm / 2.1”
Mounting diameter of tweeter 48 mm / 1.89″
Mounting depth of tweeter 48 mm / 1.89”
Voice coil of tweeter 28 mm / 1.1″
Cone of tweeter Hand coated silk
Housing of tweeter Black matt anodized
Magnet of tweeter Dual Neodym
Power handling W RMS 130 (Woofer) / 70 (Mid) / 100 (TW)
Power handling W peak 210 (Woofer) / 110 (Mid) / 150 (TW)
Impedance4 Ohm
SPL 90 (Woofer) / 87 (Mid) / 90 (TW)
Normal minimum signs of usage present on the components however the condition is easily 8.5/10
For Price, please send me a PM, whatsapp text me on +4915258583789
