Kenwood KAC-6404 4/3/2 Channel Power Amplifier
- 14.4V Rated Output Power (4 Ohm, 20 ~ 20 kHz), 1% THD: 4 x 40 W
- 14.4V Rated Output Power (2 Ohm, 1kHz), 0.8% THD: 4 x 60 W
- 14.4V Bridged Output Power (4 Ohm, 1kHz), 0.8% THD: 2 x 120 W
- 14.4V Maximum Output Power (4 Ohm, Bridged): 500 W
- Built-in Low-pass Filter, B Channel: 80Hz (-12dB/oct)
- Built-in High-pass Filter, A Channel: 80Hz (-12dB/oct)
- Variable input sensitivity: 0.2 ~ 5 V
- Frequency response: 10 ~ 50 kHz
- Signal noise ratio: < 100 dB
- Maximum current consumption: 21 A
- Dimensions (WxHxD): 330 x 60 x 230 mm
- Weight: 2.6 kg
- 2 Ohm Load Capability
- Aluminum Die-casting Heat Sink
- Speaker Level Input
- RCA Line Input Terminals
- Power MOSFET Switching Power Supply
- Power Indicator with Red LED
Only Few Months used.
Never Repaired Nor Damaged.
Reason For sale : Already Upgraded to excelon KAC 645
Price : 6000
Contact : 333 425 6800
or
You Can PM me.
