Hello guyz I`m here to sell high quality car audio amplifiers, some of which are rare sq amplifiers loved by many for their build and sound quality.
More Amplifiers will be added here in this same thread, you can contact me at 03214877172
Other Car Audio Equipment (Speakers, Woofers, Players) are also available, call for more details.
A) 4 Channel Amplifiers
1. Addzest APA-4200G (King of SQ Amps) Made in Japan
This Amplifier along with its big brother 4400G are regarded as top SQ amplifiers, with builtin Mcintosh Power Gaurd technology you are assured distortion free audio. This Amp is under rated and can deliver much more than 50watts per channel.
- 4x50RMS @ 4-Ohm Stereo
- 2x100RMS @ 4-Ohm Bridged Mono
- Frequency Response: 10Hz-50kHz
- THD @ Full Output 20Hz-20kHz: 0.02%
- Signal/Noise Ratio: >115dB
- Built-In Variable High/Low-Pass Filter: 50Hz-200Hz (-24dB/Oct.)
- Bass Extender (Boost): +1-+12dB @ 50Hz
- PWM Power Supply
- Power Guard Circuit
- Gold Plated Terminals
- Fan-Forced Cooling
- RCA Pre-Outs
- FET Power Supply
- Recommended Fuse: 1x30A
3. Kenwood KAC-941 - Made in Japan
Manufactured in Japan in 1989, this is kenwood at its finnest, if you are looking for one of the most sweet sounding amplifier in small package this one is for you, A 34 year old in this condition is unbeatable.
40x4 @ 4ohm
SN: 105db
Damping Factor 105
4. Carrozzeria GM-A3400
60W x 4 @ 4Ohm
5. Panasonic CY-M9054 - Pair
50W x4 A very rare bread of Amplifier manufactured by Panasonic availabe in Pair, Great Sound Quality.
6. Panasonic CY-M9004 - Made in Japan
45 Watt - 4 Ohm - 20 - 20000 Hz - THD 0.08% - 14.4V DC - 4 channel(s)
7. Sound Magus CS 550.4 (Brand New)
80W x 4 @ 4 Ohm High Efficient Class D Amplifier in small foot print
B) 2 Channel Amplifiers
1. Carrozzeria GM-X7200
50w x 2 @ 4ohm
2. Pyramid PB-300G Golden Series
75W x 2 @ 4ohm
3. Crush CS-800 Made in USA
2ch 1Ω compatible high current power amplifier
PEAKPOWER: 800 W (ch) 1600 W (bridge)
4. Auto Bahn ACA-5102 (Brand New)
100W x 2 @ 4ohm
C) Mono Amplifiers
1. Directed D1200
300 watts x 1 chan. @ 4 ohms
400 watts x 1 chan. @ 2 ohms
600 watts x 1 chan. @ 1 ohm
2. Directed D2400
400 watts x 1 chan. @ 4 ohms
800 watts x 1 chan. @ 2 ohms
1200 watts x 1 chan. @ 1 ohm
D) 6 Channel Amplifiers
1. Rodek SP-110.6 (Brand New)
Great Power and performance in a single package
Frequency Response: 12 Hz ~ 45 KHz
Signal to Noise Ratio: > 110 db
T. H. D.: <0.05%
Subwoofer Filter: 30 Hz ~ 500 Hz / 12 dB
High Pass Filter: 40 Hz ~ 800 Hz/ 6 dB
Damping Factor: > 120
Bass Boost: ATC 35 A x 2
