Hello Friendz....
My Ultimate SQ setup is up for sale now... reason for seling is upgrade to SPL system . Both Pioneer PRS subwoffers are in neat condition and unrepaired as you can see in Snap . i AM SELLING SUBs + Amplifier . Amplifier is audiobahn A2200HCT . Its very powerful amp and can run any setup as it gives pure 1600 RMS on 1 ohm .
price reduced
1 sub sold
stuff available with reduced prices
1 prs sub = 6500
1 718 = 3400
audiobahn amp = 13,000
sealed mdf enclo for dual sub = 1000
1-AUDIOBAHN A 2200HCT........ Price (13,000 RS )bit negotiable
Audiobahn A2200HCT 3200W Max, High Current 2-Channel Amplifier
3200W Max, High-Current 2-Channel Car Amplifier
RMS Power Rating:
- 200 watts x 2 chan. @ 4 ohms
- 400 watts x 2 chan. @ 2 ohms
- 800 watts x 2 chan. @ 1 ohm
- Bridged:
- 400 watts x 1 chan. @ 4 ohms
- 800 watts x 1 chan. @ 2 ohms
- 1600 watts x 1 chan. @ 1 ohm
Max Power Output: 3200 watts @ 1 ohm
Wired Remote Bass Level Control Included with Blue Illuminated Knobs
- Also illuminates red to indicate when amplifier is clipping
High-Current, Non-Regulated Power Supply
Preamp Outputs
Cobalt Blue LED Illuminated Heat Sink Design (on/off switch for your preference)
Thermal Regulated, Air Induction Dual Cooling Fans
Double Sided PCB (Circuit Board)
High Gloss Chrome Plated Finish
Unique, Clean Chrome Fire/Flame Design
Blue Illuminated VU Meters Indicating Output Response
Clear Power and Speaker Connectors
Variable Bass Boost: 0-18dB @ 40-100Hz
Variable Low-Pass Crossover: 40-120Hz
Variable High-Pass Crossover: 50-750Hz
Variable Subsonic Filter: 20-50Hz
Signal-to-Noise Ratio: 100dB
Frequency Response: 10Hz-40kHz
THD: 0.05%
Channel Separation: 50dB
Input Sensitivity: 200mV - 8V
1/0- or 2-gauge power and ground leads recommended. Contact us for information regarding a discount on a select amplifier kit when purchased together.
Dimensions: 23" L x 11-15/16" W x 2-1/2" H
2 - 2 X Pioneer PRS SUB along with sealed 2.75 cft MDF enclosure ....... Price (17,000 = 15000+2,000 )
Pioneer TS-W12PRS (tsw12prs) 12" PRS Premier Reference Series
<TABLE class=product_features_table><TBODY><TR><TH colSpan=2>Subwoofer Specifications</TH></TR><TR><TD class=feature_name>Subwoofer Size</TD><TD>12"</TD></TR><TR class=alt><TD class=feature_name>Subwoofer Design</TD><TD>Round / Circle</TD></TR><TR><TD class=feature_name>Main Cone Color</TD><TD>Yellow</TD></TR><TR class=alt><TD class=feature_name>Voice Coil(s)</TD><TD>N/A</TD></TR><TR><TD class=feature_name>Impedance (per voice coil)</TD><TD>N/A</TD></TR><TR class=alt><TD class=feature_name>Peak Power Handling</TD><TD>1200 watts</TD></TR><TR><TD class=feature_name>RMS Power Handling</TD><TD>300 watts</TD></TR><TR class=alt><TD class=feature_name>Woofer Composition</TD><TD>Kevlar</TD></TR><TR><TD class=feature_name>Woofer Surround</TD><TD>Urethane</TD></TR><TR class=alt><TD class=feature_name>Minimum Sealed Box Volume</TD><TD>N/A</TD></TR><TR><TD class=feature_name>Maximum Sealed Box Volume</TD><TD>N/A</TD></TR><TR class=alt><TD class=feature_name>Minimum Ported Box Volume</TD><TD>N/A</TD></TR><TR><TD class=feature_name>Maximum Ported Box Volume</TD><TD>N/A</TD></TR><TR class=alt><TD class=feature_name>Sensitivity</TD><TD>92 dB</TD></TR><TR><TD class=feature_name>Frequency Response</TD><TD>15 - 2000 Hz</TD></TR><TR class=alt><TD class=feature_name>Xmax (millimeters)</TD><TD>N/A</TD></TR><TR><TD class=feature_name>Top Mount Depth</TD><TD>N/A</TD></TR><TR class=alt><TD class=feature_name>Shallow Mount Installation</TD><TD>No</TD></TR><TR><TD class=feature_name>Cutout Diameter</TD><TD>N/A</TD></TR><TR class=alt><TD class=feature_name>Recommended Enclosure Type</TD><TD>N/A</TD></TR><TR><TD class=feature_name>Subwoofer Grille</TD><TD>No</TD></TR><TR class=alt><TD class=feature_name>Re-Cone Kit Available</TD><TD>No</TD></TR></TBODY></TABLE>
3- pair Of kenwood 718 (3500 fixed)
set was installed in car so it hard to take pics . 718 are in perfect condition unreapired and 100 % genuine . buyer can check it in car as is was currently installed .
Please contact for further information / offers on my cell number 0333-4496606 . thanks
