does OEM suggest to use this 5w-20 motor oil ? or you are using by your personal choice ?
However according to my own preference, the fuel average should always be calculated with ac on.
The cranking noise on speed bumps seems from the suspension.
Plz address the items like ball joints, control arm bushings, play in steering rack, play in axles or some broken boot, etc.
Honestly, 2017 wagonR with only 37K driven doesn’t ring the bells. Are you sure its odo meter is not reversed.
