The logic that i came up with is simple, when u use bigger or smaller tires from the OEM specified tires, the meters readings differ, i.e smallers and bigger tires vary the distance covered hence different readings while same distance covered with different tires.
Which means different fuel average with different tires and readings
Where as actualy it remains the same. Only numbers change because the bigger tires travel more distance in less rotations while smaller tires cover less distance in more rotations
