What should be the fuel pressure of a Vitz with 1kr-fe at the fuel rail?
or in what range? as in 40psi to 50psi or what?
should be right abt there 42psi i guess
Thanks mate.
How do I go on about checking it?
it has no test port :S
I can get the gauge no problems, but can we use a 'T' before the fuel rail? to attach the gauge and check? or is there any other way to do that?
The correct way to test it is a proper toyota tool, its a 3 way adapater that connects to the quick release of the fuel rail.
You can try to make it with a junk injector rail and injector pipe with a T in the middle and a gauge.
@ sync i hope u dont mind me asking an off topic question here @ Xulifqarwhat should be the correct fuel pressure of a toyota 2nz-fe?
same about 42 to 50 psi
I went to the nearest toyota stealership, they didn't have it. No concept of checking fuel pressure! :s
What kind of a gauge should I buy for the purpose?
Using Car scanner pro with JOBD protocol for Passo 2007. I will post screen shot of this in a while and also fuel rail pressure is too high must be wrong interpretation from ecu which is around 50,000 psi
There's no fuel rail pressure sensor in passo.
This topic was automatically closed 2 days after the last reply. New replies are no longer allowed.
