For your comments.....................
table cellpadding=0" cellspacing=0" width=100%"
tbody
POWERMAG: Magnetic Fuel Saver is a perfect and amazing automotive assembly designed to condition the fuel prior to combustion to increase power output, save fuel, and reduce emissions:
1) Powermag: Magnetic Fuel Saver can help engine to burn fuel more efficiently
2) Powermag: Magnetic Fuel Saver let your car run more miles per gallon
3) Powermag: Magnetic Fuel Saver will improve engine performance
4) Powermag: Magnetic Fuel Saver will reduce emissions
5) Powermag: Magnetic Fuel Saver will clean air
Magnetic Fuel Saver gadgets increase combustion efficiency for a cleaner burning engine. This reduces harmful emissions while increasing engine performance.
Enjoy these benefits of Magnetic Fuel Saver
1) Save fuel, save money, more miles per gallon
2) 50% reduction of carbon monoxide and hydrocarbons
3) Helps pass emission testing
4) High octane performance with lower octane fuel
5) Improved performance - quicker starts
6) Stops scale build-up and corrosion in engine
7) Reduced wear on O2 sensor and catalytic converter
The Fuel Saver can be used in:
â—† Cars
â—† Buses
â—† Trucks
â—† Scooters
â—† Generators
â—† Motorcycles
â—† Ambulances
â—† Gas Cylinders
â—† Autorickshaws
â—† Locomotives / Trains
â—† Earthmoving Equipment
â—† Construction Equipment
/tbody
/table
