My YBR is running fine with regular/supreme fuel.
Usually fill from PSO or Shell.
Although YBR's engine compression ratio is 10:1, which is higher than most other bikes. And it'll probably allow you to use high octane as well if you are feeling adventurous.
Engines with compression ratio of 11 and higher usually require high octane only.
Found this chart on quick googling....
