When i changed oil after 4800km. . Mechanic says ur oil is in good condition. . Don't change it. . I said i have driven around 4800km already. . Its time to change i think. .
I wanna know, oil condition also matters when changing it or i just stick to the mileage i.e 5000km?
Although oil was in good condition, still car burnt half a litter. What does it show? Is it normal for 1KR-FE engine or engine is in bad condition a bit?
I pour 3litrs with oil filter this time and dipstick showing a bit less this time. . This only happened this time as mechanic drained out using pump.
.. he said pump usage is the best way to do it. . Simple way from bottom may result some oil still remain inside. . Is it true?
According to manaul it shoud b 3.1liters. . Mechanic says we normally pour 3.4 liters with filter change. . should i add a bit more to top up?
