Dear syedozair!
Me Asif from Peshawar. A Cuore owner. I also faced this problem of fuse some three months ago and it was caused by one faulty component. I am kinda investigator and search for core issue causing big problems if ignored.
I found out after 5 blown fuses (Guage/Turn, right next to Engine fuse) that there is some problem with the reverse switch attached to the gear box which turns on the reverse light when in operation. Though i didn't fixed the reverse switch yet but found a simple solution by finding a genuine Japanese fuse and since then i faced no problem. (I'll fix the reverse switch asa this lockdown ends).
Second thing was "Desi" fuses which doesn't last long and the picture you shared shows good number of Desi fuses in your fuse box and a missing relay.
I hope you find the core issue and make your ride a trouble free ride.
