Mod Edit: Title edited.Selling D15b3 engine and some stuff from D15b vtec engine. All parts are in working condition, Just needs some cleaning.
1) D15B3 "carby engine assembly" (Require a complete engine overhaul)10'000rs
2) PO8 ECU (Manual) ( Can be used on Honda D, B,F,H series engine)7000rs (SOLD)
3) D16 Intake manifold with MAP sensor, Idle Air Control Valve (IACV),fuel rail and injectors (without TPS sensor) Better than D15b intake manicall*
4) D15B OBD1 Distributor (Only Cap needs to be replaced, Cap is broken)2500rs
5) Honda OEM OBD1 D series Engine Alternator4500rs
6) Exhaust manifold (with heat shield)4000rs
7) D15b Stock Flywheel3000rs
8) D15b Water Pump3000rs
9) Gear console and Cd/Cassette holder (for Honda Civic 84-87)1000rs
10) Honda Civic 92-95 radiator. 500rs
For details, Contact : Habib 0332-3029233
Ecu sold!
best of luck dude
^ Thanks.
PM sent
@ UIV
Check your PM.
Radiator looks like this one ( Not original pic)
how much for this ?
@ Badpigs
Could you weight the flywheel?
@ spoonsportsI haven't weighed it but I think the stock one weighs between 17.5 to 18 pounds.
How much weight of STD. ZC flywheel?, also D15B. - TheZCR.com Forums
Bump
No one is interested ?
bro how much for radiator
Let me know the price and availability of the Intake Manifold please
@ rohaansaeed
Demanding 4k for the D16 Intake manifold with MAP sensor, Idle Air Control Valve (IACV),fuel rail and injectors (without throttle position sensor)
