your problem is not plugs, your engine is badly misfiring because the piston crowns are coked up and not permitting a strong tumble of the air charge, the misfire will cause the plugs to be black as tar.
Its a GDI design flaw and you will need to get into it really deep to clean that out - (hint - its not possible with chemicals, you need physical attack on the hard carbon - like shell blasting)
