@Xulfiqar.Which gear and engine oil should be used in daewoo racer.For engine oil iam using zic 10w40 api sn and for gear oil zic gear ff 75w85 1.8l is it correct.
It's fine
Perfect Bhai. Engine oil should not be more than 10W40.
I have heard some where that Daewoo takes atf with gm synchromesh in its transmission.
Is GM synchromesh available in Pakistan.
I had searched for it in whole pak but failed...asked xulfiqar and he said gl4 75w-85 is ok for that
