Hello..
i have toyota corolla 94 JDM AE100 with 5a-fe engine.. few days back i noticed that gear is grinding in 1st and 2nd gear.. i went to mechanic.. he changed clutch and pressure plates.. and repair the gear synchronizer.. also changed gear oil with caltex gear oil, after this work.. there is little bit grinding in all gears :s again i went to mechanic.. he said.. after few days.. it will be fine.. (ravaan hojaye ga)
but sometimes (NOT every time) there is too much grinding (mostly stuck) between 1st to 2nd gear and 2nd to 1st gear.. even clutch was fully pressed
waiting for help !
Ovais.
POSTED on 11-01-2013
POST UPDATE :- 30/1/2013
ASsalam U Alaikum..
changed gear oil with caltex thuban 80w/90..
also change cluth oil with seiken DOT 3
now kabhi kabhi.. 10 - 15 days main 2, 3 baar gear shift hi nahi hota.. first gear lagta hi nahi hai.. engine off karnay k baad gear aasani se shift ho jata hai.. aur phir chalao to koi problem nahi hoti..
clutch cylinder checked.. us main koi nipple hoti hai.. us main kaafi kachra tha.. so bhi saaf karwa chuka hon 15 days pehle..
please help.
