you are facing low transmission oil line pressure problem. it can be fixed by following methods after full diagnostic.
1:CVT Pressure calibration.
2: G sensor relearning
if the problem doesn't solve by uper mentioned procedure's then you need to perform valve body assy service to counter the jamming pistons movement in the valve body assy.
