amplifier stability is always considered by its current power in use
i can hook it 0.1ohms, making sure i dont let circuit to make amplifier produce more then its rated rms
i am still out of these things ,all interest over this is my final year BS
that was pretty good i enjoyed at right time ..
these are d4s @ 1 ohms ,
1 year ago i switched from d2s to d4s , amplifier is even stable at 0.5 ohms
i repeat dont worry about 0.1 ohm even ! , all matter is how much power amplifier is said to produce
amplifier will be stable even if its connected 0.1 ohms , and the power draw is less then power that amp produce on least ohms 1 ohms
output power
0.1 ohms (1400wrms taken out) Stable (more lower gain settings)
1 ohms (1400wrms taken out) Stable ( gain to max)
in both way amp is stable
