Hello,
I bought this Kei car in February and replaced the worn out generator/AC belts with local ones as OEM belts weren't available. I had them tightened a few times and they worked for 2,3 months until I had to replace them a month back.
Alternator belt broke a couple of weeks back when I was with my family. My electrician did a band aid fix by replacing both belts with a new pair and told me that he had found a loose bolt that was not checked earlier and this should permanently fix it. I couldn't stand and argue at 3pm with my family sitting in the car.
Last week, it again made those squeals, but this time I felt they had tightened it too much. I went to them and they loosened them for me.
Four days back, the noise seemed reminiscent of the one that was the precursor of the belt breaking so I went to the same workshop. They said, the pulley is too smooth and sharp, so they need to replace the generator pulley which I eventually did and replaced it with a Kabli one.
It has been 3 days and tonight I travelled to Islamabad and the sound was horrible. I just came back and am thankful I am not on the road at this time.
Symptoms: The belt makes squealing chirpy sounds (mostly at night), when lights and AC are on. Squealing starts when I brake at a signal and when it gets worse and the belt is nearing its end, it squeals at every turn or braking, or moving from idle state.
Turning lights off fixes it in most cases. In worse cases, I have had to turn off AC, headlights and shift car to neutral. It is not nice approaching every signal with headlights off or leaving a signal doing the same.
Summary: So far, I have replaced 3 belt pairs, 1 pulley, had belts tightened and loosened to absolutely no effect. My car has eaten away 3 belt pairs in less than 500 km. Generator belt is most worn but I get both replaced just to be sure. Obviously, these guys aren't doing their job well and I need to go to someone else. Reason I haven't gone to anyone else is because my father and elder brother kind of have a soft spot for these guys. I am going to go to someone else this time, in any case, but I need to know what specifically I need checked and the possible fix. I do not want another band aid fix and do not want myself stranded on the road in Ramadan.
My own take: I have a hunch generator bearings might be stiff. They are probably not letting the generator pulley spin as fast as the engine is trying to spin it through the belt and the belt might be heating and shedding off as a result. I noticed a lot of belt debris in generator pulley grooves and around the pulley area.
Is that plausible?
Any suggestion/comment/advice in this regard is sincerely appreciated.
