well i have think about that a lot ,,,,,,,,,,,,,previously i though installing a fx cylincer will fix this problem,,,,,,,,,wrong,,,,,,,,,,,800CC exhaust cant work on 163 cc engine,,,,,,,,,,,,you have to instal a 4 stroke 200cc riksha exhaust which is almost the same size as that of fx ,,,,,,,,,,,,,,,
if you messing with some mechnical noice then sort it out as well,,,,,,,,,,,lose tappets can produce noice,,,,,,,,,,,,,denmo bearing can also make noice,,,,,,,,,,,,,replacing the cam shaft with teflon can make engine much silent , but i guess lioncin come with teflon cam shaft,,,,,,,,,,,,,,
