@moizirfanI bought it for RS 350.it's coil input is 220v
Adjust its tappets.
I once tried it with a compressor trying to start the generator on a compressor but the pressure was too much so the generator could not start, I think same will be the problem with this heat gun plus you will have to adjust gas settings again and again
where did u buy it?
no dude just set it to 4 or 5 and all good , or do bridge connections
i am working on it to automate it so that a stable pressure is provided to kit, still working fine almost 50+ i have installed in my city.
finally i received my parts, so lets just do it Grip placed from backside of the connection box. will be used to connect ATS easily just plug and unplug
tools required to make some adjustments to connect box or gene panel.1. Drill2. steel drill bit3. nose pliers 4. cutter pliers5. colour wires6. tester7. Grip8. ON OFF ON two buttons
inside view of box ; wires from grip.
find some gap in tray and make two holes of button sized in gene panel tray.
fix button inside holes.
backside / inside view of plate.
added extra wires for,petrol solenoidoil alertht coilself solenoid
because i hate ripping and cutting wires.i just put the previous wires to switches and new wires from switches to components.
addition of separate wires for each component,selfpetrolht coiloil alert
fuel pipe (pieced about inches in size) to insulate the buttons connection.
Hall road Lahore
Sent from my IM-A850S using PW Forums mobile app
@moizirfanHow would i know which point of time delay circuit is common,normally open or normally close?
wires connected to switch(button) and insulated using fuel pipe pieces and switch is ready to be placed inside the hole that we made in a tray.
i just fixed the wires first because that would be tough for you to fix them in congested place with other wires
another view of the insulated button.
