agoodfriend, a_n_memon88, hanimughal or any one
I am new to this forum, can any one help me. I have 2 kva jassco generator last year I got it overhauled,few days back it started to make problem,even now it starts on half crank at petrol and shifts easily to gas as well but when load is put on generator (not every time) it starts to vibrate till that extend that one will feel gen is going to close (i feel this is not due to load, i believe it is gas setting) and then pick up and run normally I check spark plug its full of carbon and this is happening quite often, previously never happened. Voltage also drop as load is gradually put on (from 230 to 218, from 2 fans and a tv plus two tube lights to 6 fans and 4 tube lights and tv plus computer) and oil level is decreasing to i have to add on 250 ml every week to maintain oil level, previously. I never added oil and use to change oil in every 15 days. today morning i have noticed that unused (unused because it was red in color as i use havoline 20-50) oil drops (its was more than a drop u can say 10 to 20 ml)on the floor below the air filter and carb side, just 3 days back i have drained old oil and re fill it with new. Any suggestion I think it's a intake valve leak, i want to be damn sure before to open head.
