you only need to adjust the governor arm ,,,,,,,,,,,, change the governor arm spring and also the throttle lever spring need to change ,,,,,,i you can open up the crank case for governor gear change then i am sure you can do this adjustment ,,,,,,,,i have share that with pic ,,,,, may be many many pages before ,,,,,,,,,,,
