Once again the same question;
My generator's RPM drop significantly at full load (Frequency drop from 50Hz to 36 Hz). I can manually increase the RPM by moving governor arm, which means engine is fine and can take load.
What I have already done is.
- Adjusted governor-throttle positions
- Changed governor gear inside the crankcase
- Changed Carburetor
- Tappets adjusted
- Plug gap is fine
- NG adjustment made
What else can I try; any help.
Note: Governor arm moves but not to its full capacity; when load is put, it goes half way and if more load is applied RPM start to decline.
