Hi All;
My generator was lacking power; I tried a lot of adjustments with tappets, plug, governor, carburetor e.t.c but couldn't succeed. Now I overhauled the engine (Sorry for not making a video); Changed rings and piston, and got Head and valves repaired.
Now the problem is that engine is only taking about 20% load. If I put more load, engine destabilizes and keeps missing even if I remove all the load.
When I remove the air filter box, I see the choke-plate vibrating like hell (opening and closing). If I push the choke plate to closed position, engine comes back to smooth operation and remains smooth even if I leave the choke-plate. Then again engine runs good unless I put heavy load.
Any suggestions
