First check your ng pressure;
1- Take a bottle more than one foot tall and fill it with water.
2- place a scale (1 Foot) with that bottle (Zero should be floor and 12 should be towards bottle's lid)
3- put the gas pipe from a gas outlet in the bottle deep to the bottom of bottle with gas opened
4- there'll be no bubbles at bottom; now slowly pull the pipe and note the inch at which bubbles start popping out of the pipe.
5- multiply that inch with 2.5 and it will be your gas pressure in millibars. You should have 20 millibars of pressure to run the gen properly. 18 may also work but less than that it's very hard for gen.
If your pressure is low try using some pumping mechanism.
If pressure is fine, then 1- clean the air filter 2- check tappet adjustment 3- check spark plug. There must be some problem in any of these. If not then borrow some working ng kit from some friend and check if your ng kit is not faulty.
Hope that helps.
