well about governor I tried to move it manually governor and butterfly moves freely no friction so I guess the problem is with governor gears, well I don't need governor anymore I have quick fixed it and my fix is working fine for me so far.
well good to know I help someone, I do have quick fix for you if you just tell me your GENE and load.
well I am working on that automation its still in beta testing mode and as you know components like UC are costly so I would not recommend or share anything until I am sure that's gona work for you. I will share ASAP when I am done and I believe that will be soon.
I can share logic that I am using for this purpose may be that help you to understand the concept, the logic is RPM controls/effects frequency (Hz) so I am trying to ADC frequency, after that by using those values I am controlling heatgun current.
