Hi, guys
I am using JASCO DB-3800 3.1 KW 8HP last two months. Changing oil every 15 days Havoline CNG. Maintained in good condition.
Recently it is giving problem: suddenly it takes hickup (hichki) once in a while dimming electric power for less than a second then back to normal.
I have thoroughly cleaned spark plug to clear doubt whether plug electrodes are OK and may be HT current is leaking but no avail. I also increased CNG pressure to clear the doubt. But problem still.
Can this problem be due to tappet clearances? I have not checked/adj since purchased. What is recommended setting on gas?
after how many hours operation should I change oil. currently I change every 15 days that is approx 80 to 90 hrs. but I am always using havoline CNG and someone recommeded to use GTX or Havoline regular red color. because havoline CNG is thin.
please suggest
