dear you batter disconect all the wires of main panel which runs to the engine ,,,,,,,,,like what i do ,,,,,,,,i have even completelly remove the main pannel ,,,,,,,,,,,,,,,to start the engine you have to connect the +ve battery terminal to the starter motor solenoid ,,,,,,,,,,,,,to kill the engine you have to ground the HT coil wire ,,,,,,,,,,,,,its very simple ,,,,,,,,,,,but it will be lot difficult for you to identify those cables from the connector of ignition switch ,,,,,,,,,
