well i guess you are reading the voltage with the inbuilt analog voltage meter which is of poor quality and chinese made and never been acurate , you need some digital volt meter and hz meter to adjust all that,,,,,,,,,,,,,,,,,,there is a sligh fluctuation of voltage which is normal and nothing to worry about that ,,,,,,,,,,,,
i will post a new and modified circuit diagram of ATS in which i have already add a cut off circuit which switches off the generator if it wont starts with in 1.5 min ,,,,,,,,,,,,,,
engine oil must be change after 100 hours and also check the oil level after 50 hours ,,,,,,,,,,,,you have noticed that chinese generator split oil from breather pipe into the air filter box ,,,,,,,,,,,,this drops the oil lever in crank case and it must be rechecked after 50 hours ,,,,,,,,,,,,,,,you can replace spark plug after 500 hours with ND spark plugs ,,,,,,never use the original chinese made spark plug,,,,,,,,,
