locate the vehicle ID Plate ( a silver plate either in the trunk or in engine bay ) locate Trans/Axle & share the code U-3xxx
in front wheel drive vehicles transmission & engine mount change require caution. The vehicle shall be levelled over jack stands. When transmission / engine mounts are fractured either one or both,
both need to be changed. Change procedure require balanced level vehicle and support for 1 while other is removed / replaced .
if the ustaad have replaced only 1 mounting in quick job by lifting one side it has caused disbalance and you are feeling the transmission sway at R & kick down throttle.
it is a mounting fault the transmission is working perfect do not fall trap to any tinbox classic mistry.
110 Tipu Block Garden Town 10 am to 7 pm 0321 4106898 Obama Car & Truck centre
